1999 Plymouth Voyager skipping
200,070 MILES • 6 CYL • FWD • AUTOMATIC
ROBBIE ANDERS
I had van checked out at auto zone the check engine light has been on forever but the reason i had it checked was because of the skip that started as told i bought oxygen senser and put it on the van seemed to have more power but it still had skip,thinking maybe i got some bad gas i have put gas treatment with no change.The van when driving feels like its holding back its power but it will gradually pick up speed but once you stop it has a rough skipping vibration i don't have the money to put it in the shop so i am hoping you can give me some advice asto what and how to check next.I have a 7 and 10 year old i have to take to school every morning your help would be greatly appreciated.Again thanks for your time!
Apr 26, 2010 at 4:09 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 26, 2010 at 6:28 PM
