TO TURN THE HEAT ON IN MY CAR YOU HAVE A KNOB TO SELECT TO HEAT OR AC. I HAD IT ON AC TODAY AND AFTER AWHILE IT JUST SHUT OFF FOR NO REASON. THE OTHER SWITCH TO TURN ON AND OFF YOU HAVE TO HAVE IT ON ALL THE WAY AND IT WILL WORK. IT WON'T WORK ON LOW OR MEDIUM IT ONLY WORKS ON FULL BLAST. I KNOW THERE IS A PROBLEM BUT I DON'T KNOW WHAT AND I NEED AN ANSWER TO FIGURE OUT WHAT IS CAUSING THIS
Oct 27, 2008 at 2:10 AM
