1999 Plymouth Voyager SERIOUS QUESTION
1999 PLYMOUTH VOYAGER
98,000 MILES • 6 CYL • FWD • AUTOMATIC
ALCIDE3086
TO TURN THE HEAT ON IN MY CAR YOU HAVE A KNOB TO SELECT TO HEAT OR AC. I HAD IT ON AC TODAY AND AFTER AWHILE IT JUST SHUT OFF FOR NO REASON. THE OTHER SWITCH TO TURN ON AND OFF YOU HAVE TO HAVE IT ON ALL THE WAY AND IT WILL WORK. IT WON'T WORK ON LOW OR MEDIUM IT ONLY WORKS ON FULL BLAST. I KNOW THERE IS A PROBLEM BUT I DON'T KNOW WHAT AND I NEED AN ANSWER TO FIGURE OUT WHAT IS CAUSING THIS
Oct 26, 2008 at 7:10 PM
  • 110,244 POSTS
Hi:
The cheapest and easiest thing to try is to replace the blower motor resistor. It is a common problem which causes your type of problem.
Let me know if this helps, and if you have any other questions.
Nov 5, 2008 at 2:48 AM
