1999 Plymouth Voyager Rattling noise and vehicle vibration
185,000 MILES • 6 CYL • FWD • AUTOMATIC
SAINTBERNARD
My van is making a rattling sound from the passenger rear wheel area whenever I go over a bump. It is also vibrating the whole vehicle at highway speeds, but only intermittently. When it starts to vibrate, I can slow down and it will eventually stop. I don't know if the two problems are related or not. I also don't know if it is pertinent information or not but I had the rear brake shoes replaced, cylinders replaced, and drums turned this past July.
Thanks very much.
Dec 13, 2008 at 12:00 PM
ZACKMAN
  • 4,202 POSTS
Pull the rear brake on that side, and check to make sure everything is in order. I think one of the springs came loose/broke off.
Dec 14, 2008 at 9:36 AM
SAINTBERNARD
Will a broken spring on the brake assembly make the whole vehicle vibrate? The vibration is similar to a badly bent rim.
Thanks for the reply!
Dec 14, 2008 at 1:02 PM
ZACKMAN
  • 4,202 POSTS
Yes, it will.
Dec 15, 2008 at 8:44 AM
SAINTBERNARD
Well, after working the 'look at the problem' time into my hectic life, I pulled the wheel again, pulled the drum, and didn't find any broken springs or anything. I can move the brake assembly up and down by hand and noticed that there are two springs, one on either shoe, with a post coming from the back of the assembly to the front and they seemed loose. I took the van to the brake shop and they say that the brakes are fine. It still rattles. Any other ideas? I think I will take it to another branch of the same chain for a second opinion.
TIA
Jan 7, 2009 at 12:34 PM
ZACKMAN
  • 4,202 POSTS
[Quote]It is also vibrating the whole vehicle at highway speeds, but only intermittently[end quote] You also may want to check these suspension parts, along with the shock absorber and the wheel (for possible bent rim - but I highly doubt it).
https://images.2carpros.com/forum/automotive_pictures/55316_99caravanrearswaybar_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_99caravanrearsuspension_2.jpg
Jan 7, 2009 at 2:18 PM
