the brake pedal is very hard when i press it, could that mean that they need to be bleed or the master cylender is bad.
Dec 31, 2007 at 2:22 AM
BMRFIXIT
✓Experienced Mechanic
[quote:3d839e255e="mtgtjgg"]Brakes problem
1999 Plymouth Voyager 6 cyl Two Wheel Drive Automatic 90000 miles
the brake pedal is very hard when i press it, could that mean that they need to be bleed or the master cylender is bad.[/quote:3d839e255e]
hard pedal usually related to brake booster
check if it vacuum supply ok
check egr
