While driving home a few weeks ago my van died. I was accelerating from a stop when it quit. It has good power and rolls over without a problem. I pulled the coil wire to check for spark, none. I took the coil to the local parts store and it tested fine. Before it quit there was a code for the EGR valve (had a rough idle). Now I can not get any codes with the OBDII and the check engine light is off (comes on with the key then goes off). I have gotten multiple votes on the computer being bad but would like another opinion.
Nov 30, 2009 at 5:24 AM
