1999 Plymouth Voyager lights
136,000 MILES • 6 CYL • FWD • AUTOMATIC
RAMROCK6
When I turn the lights on....the headlights come on only. No rear running lights and one brake light is working (passenger side). The gauge lights do not come on and neither does the tag light. Turn signals work though on both sides. On the bulbs are good and so are the fuses. Please help! Was pulled over the other night.
Feb 2, 2010 at 7:24 AM
CH112063
  • 1,320 POSTS
The dash illumination has many tiny bulbs that were replaced all the time, you need to test that small fuse with them turned on. You may have a bad combination switch, cause that covers everything. You need to use a test light and get behind each bulb socket to test for power. Buy one at the store they have here and read how to use it. If you already have start with one item at a time, and remember there are fuses and relays in two locations, inside and in the engine compartment. And good luck also. If you remove a fuse in the interior fuse box, and it looks good, it still doesn't let you know that power is available from the underhood power center, the whole vans power source.
Feb 4, 2010 at 2:01 PM
