1999 Plymouth Voyager Leaking coolant
1999 PLYMOUTH VOYAGER
LOJOANI
Engine Cooling problem
1999 Plymouth Voyager Two Wheel Drive Automatic 111000 miles
The outer rib of the main belt started to separate as I was driving (I heard the noise but couldn't figure out what it was because when the van was stopped the belt looked fine and had tension). When I got home, the belt popped off just as I pulled up to the house.
I've replaced the belt. when I started the car, it made a not-normal noise, kinda high pitched, squeeky. The coolant I had just replaced came pouring out of the bottom of the engine. Because of the plastic plates on the bottom of the engine and how crammed together stuff is, I can't figure out where it is leaking from. The coolant container is fine.
What's the best place to check for the leak?
Nov 23, 2008 at 7:25 AM
  • 31,937 POSTS
HI there,
You will need to do a pressure test and check carefully with a torch, there are a lot of places the coolant can leak, take your time and you should see it.
Mark (mhpautos)
Nov 23, 2008 at 7:29 AM
