1999 Plymouth Voyager Insterment panel dead, dead spot in s
191,782 MILES • 6 CYL • FWD • AUTOMATIC
DEPALMABRZ
Please the insterment panel was working after a light tap on dash board now dead. checked all fuses witch are good,plus i have a dead spot in starter. could this be related? Help me please
Nov 7, 2010 at 2:24 AM
JDL
  • 16,098 POSTS
Are you saying the gages don't work or no dash lites? The instrument panel cluster may be faulty? Any applicable fuse, use a voltage tester, see if there is voltage at the fuse circuit. Even if the fuse is good, if no voltage, the circuit is dead. You may have to get at the instrument cluster connector.
Nov 7, 2010 at 5:39 AM
