1999 Plymouth Voyager ignition switch
1999 PLYMOUTH VOYAGER
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRIU
how do you remove the key cylinder from the steering column?
the ignition switch is broken
Nov 3, 2008 at 11:36 AM
  • 110,244 POSTS
Hi:
The steering wheel will need to be removed. Because it has an airbag, I would recommend you have it done by a technician.
Nov 4, 2008 at 2:50 AM
