Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Voyager
Ignition
Coil
Test
1999 Plymouth Voyager ignition coil Testing
1999 PLYMOUTH VOYAGER
16,700 MILES • 6 CYL • FWD • AUTOMATIC
2OOL MAN
MEMBER
1 POST
How do I test the ignition coil on a 99 plymouth voyager with 3.3 L engine
Jun 12, 2008 at 1:09 PM
BMRFIXIT
Experienced Mechanic
do you have a no start /no spark
you may need to check and or replace crank sensor
you can check it by using an ohm meter
Jun 12, 2008 at 1:42 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
