1999 Plymouth Voyager ignition coil Testing
1999 PLYMOUTH VOYAGER
16,700 MILES • 6 CYL • FWD • AUTOMATIC
2OOL MAN
How do I test the ignition coil on a 99 plymouth voyager with 3.3 L engine
Jun 12, 2008 at 1:09 PM
BMRFIXIT
  • 19,053 POSTS
do you have a no start /no spark
you may need to check and or replace crank sensor
you can check it by using an ohm meter
Jun 12, 2008 at 1:42 PM
