1999 Plymouth Voyager hose from thermostat housing
1999 PLYMOUTH VOYAGER
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
TREY5SEVEN
my voyager has a hose leading from the thermostat housing down towards i think my water pump. not a hose from the radiator but a hose on housing under radiator hose.this small hose[img:914560d4cb]http://www.2carpros.com/forum/automotive_pictures/538492_jk_1.jpg[/img:914560d4cb] has broken off of something apparently. but i dont know what it is and what i need to replace it. the hole looks like it has threads for something to thread inside of it. bought car used and feel it was rigged to last temporarly.inside the hose has the remains of something maybe metal but is deteriorated so bad cant make it out. i included picture of hole on top where hose is suppose 2 go. and i included picture of hose with deteriorated fitting[img:914560d4cb]http://www.2carpros.com/forum/automotive_pictures/538492_cool_1.jpg[/img:914560d4cb]
Jun 13, 2010 at 4:37 AM
CARADIODOC
  • 34,381 POSTS
Hi trey5seven. Welcome to the forum. That's the water pump bypass hose. The fitting rarely corrodes away like that so you should be able to find one in a salvage yard. Getting the old one out will be the hardest part of the repair. They are usually made of brass so you can't weld a nut to it. It will probably crumble if you use an Easy Out. The best solution might be to drill it out and retap the hole. If you take the replacement fitting to an auto parts store, they should be able to match it up with the correct size tap. It will likely be pipe thread.
Before you drain any coolant, you might consider using a cheap digital voltmeter to test the coolant for its acidity. Place one probe on ground and the other probe in the coolant in the filler neck. I can't remember what the magic number is but the higher the reading, the more acid has built up in the system. The coolant normally becomes acidic over time. Any two different metals and an acid causes galvanic action, (a battery), which leads to corrosion. The cooling system has parts made from brass, copper, aluminum, iron, lead and tin. I would have to think the previous owner didn't change the cooolant on a regular basis to remove the acids. Also, new antifreeze has additives for corrosion protection and water pump lubricant that wear out in about two years.
caradiodoc
Jun 13, 2010 at 7:32 AM
