1999 Plymouth Voyager Grinding Noise
BDOGDRUMS
Vitals:
97,000 miles
2.4L 4 cyl
Recently, a grinding noise has made it's way into my engine compartment. It's a noise that exists 100% of the time the engine is running, and it intermittently gets louder during runtime. I have done some preliminary testing to see if the noise is consistent with the heating and AC system, but that has been inconclusive.
Under the hood, it seems to be one of the devices off of the drive belt, around the alternator.
While I'm not a complete novice at auto repair, I'd like to try and repair this one myself, if at all possible.
Thank you all for your expertise.
Nov 6, 2006 at 2:41 PM
BOOTDOG
  • 665 POSTS
ok, to check this problem, if u have more than one belt, take off the outer belt first then start the engine. if the noise goes away, then look into finding out which pully is making the noise. i have found that a grinding noise coming from the engine area is either the alternator, tensioner pully, ac acompressor, or idler pully. still check them all. another way is to (with all the belts on) take a long screwdriver and put the handle up to youe ear and touch the blade end on all suspected parts to see if it gets louder on some parts and not as loud on others. also remove all belts and with your hand grab the pulleys and feel for any play and roughness. i usually start with the alternator first. hope this helps
Nov 11, 2006 at 12:12 AM
Suggested Repair
Isolate the belt-driven component causing the grinding. If there is more than one belt, remove the outer belt and start the engine; if the noise stops, inspect the related pulleys. Likely sources are the alternator, tensioner pulley, idler pulley, or A/C compressor. Use a long screwdriver as a listening tool, then remove the belts and check each pulley by hand for play or roughness, starting with the alternator.
Conversation Summary
The owner of a 1999 Plymouth Voyager with 97,000 miles reports a grinding noise that is present whenever the engine runs and sometimes gets louder. It appears to come from a belt-driven component near the alternator, and heating and A/C tests were inconclusive. The expert recommends removing belts one at a time, listening with a screwdriver, and checking the alternator, tensioner, idler, and A/C compressor pulleys for roughness or play.
