Open the hood and have a helper start the car and, with foot on the brake, shift through the gears as you stand to the side and observe the engine. If it torques more than slightly, have your motor/transmission mounts replaced. You can inspect one easily, a small square attached to the back of the front bumper rail. There are two others. They use rubber to absorb vibrations and shock. The rubber gets worn out and/or breaks over time.
SPONSORED LINKS
Wednesday, April 21st, 2010 AT 1:00 PM
