Where can I find a diagram of the inside fuse box. I am trying to figure out which relay is the BAS relay.
Sep 29, 2010 at 12:53 AM
WRENCHTECH
✓Experienced Mechanic
What is a BAS relay?
Sep 29, 2010 at 1:28 AM
JKNAPP1
MEMBER
[quote:17f8efdf4e="Wrenchtech"]What is a BAS relay?[/quote:17f8efdf4e]
Sorry, fat fingers. ABS. Anti-lock brake system.
Sep 29, 2010 at 1:50 AM
WRENCHTECH
That system doesn't have a relay
Sep 29, 2010 at 2:00 AM
JKNAPP1
MEMBER
[quote:56ca683993="Wrenchtech"]That system doesn't have a relay[/quote:56ca683993]
Thanks.
Sep 29, 2010 at 2:41 AM
JKNAPP1
MEMBER
[quote="jknapp1"][quote:e2d7dc94f7="Wrenchtech"]That system doesn't have a relay[/quote:e2d7dc94f7]
Thanks. Any idea why the ABS light comes on when started and then goes out. But when I drive the van the ABS light comes back on at around 15 mph.
Sep 29, 2010 at 5:13 AM
WRENCHTECH
The ABS light works just like the check engine light. It recognizes a malfunction and then stores a trouble code to identify what it sees. The way it sets the code tends to point to a speed sensor problem but you will still need the code number to identify which one.
