1999 Plymouth Voyager fuel pump
TVARGO
Engine Performance problem
1999 Plymouth Voyager 4 cyl Front Wheel Drive Automatic
How does one drain the tank so you can get to the fuel pump. We have a full tank of gas and need to change the fuel pump. It has a device in the neck, that we cant put a hose down in it.
Nov 14, 2009 at 3:45 AM
FUBARBUN
In the past, we have gone as far as removing the inline fuel filter and using a catch basin to collect the gas...However, we did have to cut the neck of the tank in order to drop it completely one time. I do NOT recommend doing this, as your gauge will never read correctly again.
Hopefully someone else will have a better way to do this, but letting the gas drain from the fuel filter is a long, yet effective method to drain the tank. You may need to jack the rear up to get the last few gallons out.
Kelly :)
Nov 16, 2009 at 2:26 PM
