1999 Plymouth Voyager Flaky thermostat?
1999 PLYMOUTH VOYAGER
THUNDAAR56
Engine Cooling problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
In the past 36 hours my van thermometer has pegged and yet not leaking fluid. Then after off for a few hours drove it for 25 miles no issue. Then after a few hours drove it for 2 miles and the thermometer quickly rises again. My thought is the thermostat is going.
Sep 15, 2008 at 6:54 AM
BABYALEX
  • 10 POSTS
replace thermostat just as preventative maintance. also these vans have horrible engine coolant temp sensors. parts store always has them wrong in computer.
schucks or any parts america-ts71171
autozone-su326
those are part numbers about 20 bucks. whats intresting about the temp sensor on these is it could increase fuel milage because the better it works the better you pcm knows how to mix fuel and air.
Oct 10, 2008 at 6:05 AM
LEGITIMATE007
  • 5,121 POSTS
babyalex is absolutely correct, we need more moderators babyalex, why not apply
Oct 12, 2008 at 2:57 PM
