1999 Plymouth Voyager Fan/PCM
1999 PLYMOUTH VOYAGER
PRJHAM
Electrical problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 200K miles
The cooling fan will occassionaly come on for a minute after the engine is turned off and the key removed. The car is not designed to do that. Our local mechanic is saying to take it to the dealer becuase the Power Control Module is sending a signal to the fan that it shouldn't be sending, making it come on when it shouldn't. The PCM is less than 2 years old. Is this repairable without replacing the PCM? Any other suggestions?
Mar 2, 2009 at 6:32 AM
  • 110,244 POSTS
Hi:
To the best of my knowledge, the PCM is not repairable.
Mar 2, 2009 at 11:40 AM
