1999 Plymouth Voyager Engine Idles Rough at Full Stop
1999 PLYMOUTH VOYAGER
213,000 MILES • 6 CYL • FWD • AUTOMATIC
EMUEHL
Van starts right away and runs well until first put into Drive or coming to a full stop (in Drive). At that point there is significantly rough "idle" at about 600 RPM or so. If I put it into Neutral or Park, the vibration goes away. There is a little bit of rough idle in Reverse at full stop, but much less than in Drive. When I take my foot off the brake and begin driving, the engine runs fine.
Symptoms seem to be worsening over time. I had engine mounts replaced a couple months back, which lessened the symptoms somewhat, but they are back.
I have noticed very little loss of performance (for this age vehicle) and my mileage is still good (22+ mpg) relative to what it's been in the past.
Dec 15, 2009 at 12:17 PM
BMRFIXIT
  • 19,053 POSTS
No check engine light on
would indicate to me that the engine is running as it should and or the PCM does not detect any fault
and no misfire
then would be checking motor mounts and tranny mount
also would suspect torque converter and would have it checked
Dec 15, 2009 at 12:35 PM
EMUEHL
Thanks. Could an O2 sensor cause this?
Dec 16, 2009 at 6:45 AM
BMRFIXIT
  • 19,053 POSTS
Very possible specially if its an California emission
Dec 16, 2009 at 8:56 AM
