1999 Plymouth Voyager Driver's Seat Belt Won't Extend
1999 PLYMOUTH VOYAGER
119,000 MILES • 6 CYL • FWD • AUTOMATIC
CONCEPTGUY
Not sure how common this problem is - I've never had it on any other vehicle. The driver's seat belt will not extend easily most of the time. Pulling on the best seems to engage the "catch" that's designed to hold during a crash. Repeated gentle pulls will eventually coax out about 6-8 inches at a time - almost like reeling in a fish in reverse. The belt has to be held out until the next section will extend, and so on, until you get enough to buckle it. If you let go and the belt retracts, you have to start over. Odd thing: it's much worse when the weather is cold. Obviously I have to replace it, but my question is, how difficult and/or expensive would this repair be?
Thanks in advance!
Dec 22, 2007 at 5:51 PM
MERLIN2021
  • 17,250 POSTS
The sticky catch problem, I havn't run into it yet, but try cleaning the reel with some Brakekleen, get the belt fully extended, then spray the brakekleen into the reel, do it a few times and see if it works! Let me know?
Dec 22, 2007 at 5:56 PM
2CARPRO JACK
  • 11,533 POSTS
A malfunctioning inertia lock in a seat belt is a serious safety item, in my opinion the seat belt should be replaced immediately
Dec 23, 2007 at 9:12 AM
