1999 Plymouth Voyager dash does not work.
130,000 MILES • 6 CYL • FWD • AUTOMATIC
BOB222
My gauges do not work, or the shift indecator light, and odemeter, the rear wiper does not work, or the rear defroster. This all started at the same time. It was done this before. then started working again. but not this time. I am not sure what it could be the dash cluster or the body control mod, clock spring.
Sep 30, 2009 at 10:42 AM
BMRFIXIT
  • 19,053 POSTS
Unplug the BCM wait a few min and reconnect if all working fine suspect BCM
common issue with the cluster the weld (solder )brake at the pin and board connection
cluster need to be remove and checked
Sep 30, 2009 at 10:47 AM
BOB222
Thanks BMRFIXIT I will try that on saturday when I am off, I will Let you know. Thanks again Bob.
Sep 30, 2009 at 11:04 AM
BOB222
I have solved the problem, It was the connector going to yhe heater control the one wire was melted. I beleve it was a ground.
Oct 11, 2009 at 11:55 AM
