1999 Plymouth Voyager Clutch not cycling
1999 PLYMOUTH VOYAGER
JAKRO1972
  • 5 POSTS
Air Conditioning problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
Is there a malfunction if the AC clutch is not cycling on and off? I entered the AC diagnostic mode and came up with no codes. It did not cycle the whole time I was charging it. Only turns off with the control switch inside.
May 17, 2009 at 12:33 AM
  • 110,194 POSTS
There is a realy that should be causing the system to cycle. If it doesn't, chances are it will eventually freeze up on you.
May 25, 2009 at 8:21 PM
