1999 Plymouth Voyager Brake Lights
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
SSUNAZ
Both side brake lights quit working, although the one in the back window still works. We have checked the fuses, and they are good. We have also replaced the brake switch, and the bulbs. The still don't work. What should be checked next?
May 12, 2009 at 3:22 AM
MIKE H R
  • 3,094 POSTS
the third brake light runs on a curcuit by itself but does go through the brake light switch. if you have a static tester { one that has a point on it and lights up when there is voltage. start at the fuses again and work your way to the brake lights. See if you are getting juice to the lights. If you are then check the ground wire. When both lights go out 90 percent of the time its in a fuse or broken wire.
May 12, 2009 at 3:39 AM
