1999 Plymouth Voyager blows 20 amp engine fuse/looses alter
1999 PLYMOUTH VOYAGER
B.WORD
Electrical problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
looses voltage /radio crakels/blows 20 amp engine fuse/replaced alternator/bypassed alternator power wire fuse doesnt blow but looses voltage then voltage comes back.
Dec 6, 2009 at 3:05 PM
CARADIODOC
  • 34,367 POSTS
Kindly put some punctuation in your post so it makes sense, and elaborate on what you've tried so far. What doesn't work when the fuse blows. Does it blow again right away? How do you bypass an alternator? What does "looses voltage then voltage comes back" mean? Give some clue as to where you're measuring this voltage. In the meantime, I'll be thinking about it.
Dec 12, 2009 at 2:44 AM
