Transmission problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
how do you know if you should replace your transmission or just repair it
Monday, April 6th, 2009 AT 11:34 PM
MECHANIC
Hi there,
If you have a problem with your transmission, I would get it inspected by a transmission specialist. They will be able to do a few tests that will help determine the extent of your problem, this will the best way to determine which way to go.
