Hi, nice site.
My problem is the front windshield wipers will not work. I have checked fuse under dash and in fuse/relay block under hood; both okay. Replaced multi-switch: wiper, washer, bright lights, turn signal. Replaced both relays under hood. At the wiring connector for the wipers under hood I am able to get wipers to run by jumping from the positive battery post to the brown wire with white stripe
I am at a loss!
I am at a loss!
Sep 20, 2006 at 7:16 AM
