1998 Plymouth Voyager Wont shift out of first
198,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEANDME
I have a 1998 plymoth grand voyager
The van wont shift out of first, took it to well known transmission man around town, figured it was the solienoid pack. No go. he looked at everything and its fine. The code pulling up is P0760. Shift solienoid C circuit malfunction... Earlier we had computer issues and computer was short circuiting.That just went away or should I say we ignored it, could this be the problem? the computer. If so which one controls this, it has three that I know of. Trying to figure it out without wasting time and money. Any help would be appreciated
Jan 31, 2010 at 4:18 AM
CH112063
  • 1,320 POSTS
Hi Mike, Seems confusing and it takes hours of training for theory, nevermind fixing it when something goes wrong. 3 computers share information, actually more but lets say 3, Transmission, powertrain, and body computer modules. TCM,BCM,PCM. Your TCM has inputs from the trans and the computers via sensors and wiring. The TCM controls the various solenoids to allow hydraulic fluid to apply different internal mechanisms. The solenoids are housed in a black covered pack in the front left part of the transmission.
If the solenoid does not respond the TCM has preset parameters that if not met store a fault code in the TCM. When a code such as yours is stored the computer tried to move the solenoid but got an improper return. This could be a bad solenoid or wiring(circuit). I hate to say it but the dealer should have information found on their scanning computer and they use a large diagnostic book to start diagnostics. The only thing you might do is check the fluid and make sure there are no obvious wiring conditions like an open or short circuit. This code was a solenoid pack code and replacing it without doing diagnostics could mean doing it again. It may be something internal also, and the PCM has codes also that sometimes are common to the problem. You could try replacing the solenoid pack but I don't think I would only because of your high mileage. Fluid thats burned or low is a sign it needs more than just a solenoid pack. Why not read the section on how your transmission works and this limp-in mode and why it occurs. The first thing I would do is smell and check the fluid.
I hope this helps you somewhat decide on whether you want to try another solenoid pack or not, if the dealer replaced the computer recently it may be covered, as the TCM controls these solenoids.
Feb 4, 2010 at 3:27 PM
