1998 Plymouth Voyager trans fliud and radiator coolant look
163,500 MILES • 4 CYL • FWD • AUTOMATIC
HASHEESH 218
i have a 1998 plymouth voyager with 163500 miles on it. the trans just recently started slipping bad so i checked the fliud level and it looked like a milkshake. i didn't know where any water would come from so i looked in the radiator and that looked just like the trans fluid. is my trans bad now or could i just put a new raditaor in the van and a coolant flush along with a full trans flush, fill and filter change?
Apr 25, 2009 at 2:12 PM
  • 75,988 POSTS
The transmission cooler compartment on the radiator is leaking internally mixing both transmission fluid and coolant
Apr 25, 2009 at 9:36 PM
HASHEESH 218
now if i just changed out the radiaotr and did a rtans flush and filter change along with a coolant flush and fill, would that fix m y problem of the slipping trans or am i too late?
Apr 26, 2009 at 12:45 AM
  • 75,988 POSTS
I'll go for it-its a lot cheaper fix if your lucky-I've been in situation with trannies nothing compared to yours such as car park for 3 days refuses to move in reverse-all it takes is fluid change and up to level.
Apr 26, 2009 at 8:57 AM
HASHEESH 218
ok. thanks for you input. i'll go ahead with my plans and let you know. thanks again
Apr 26, 2009 at 9:02 AM
HASHEESH 218
welll i got the trans flushed and a new filter put in along with the coolant flushed. it took a few days for the trans to start shifting but it now shifts just fine and i have had no slipping since the work was done. i know i am very lucky. it has been working for me so i hope this helps others if they can catch it right away.
May 27, 2009 at 12:59 PM
  • 75,988 POSTS
Good news-attaboy
May 27, 2009 at 3:28 PM
