1998 Plymouth Voyager Torsional dampener
1998 PLYMOUTH VOYAGER
20,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOOKDAD
I am trying to remove the center bolt on the crankshaft pulley/tornsional damper unit. How do I do that? The pulley just turns when I try to remove it. I read to jam it with a screw driver. But I don't see where to put it. I tried to jam it by putting the screwdriver through one of the upper camshaft sprockets, but ended up breaking the screwdriver.
Jan 31, 2009 at 7:23 AM
JALOPYPAPA
  • 467 POSTS
If you can remove the cover plate below the flywheel and jam the blade of a large screwdriver in a tooth of the flywheel, that may work.
Feb 8, 2009 at 1:30 PM
