1998 Plymouth Voyager speedometer
120,000 MILES • 6 CYL • FWD • AUTOMATIC
RICKJ3
i have a 1998 plymouth voyager. all the gages work exept the speedometer untill u get up to about 50 and it will start reading 20 mph and up what would cause that
Feb 19, 2009 at 6:23 AM
  • 110,248 POSTS
Hi:
Remove the cable from behind the dash and spray a little WD40 into the cable. Also, when you have it apart, see if you can spin the cable. If you can, the cable is broken internally. If you can't spin it with your fingers, it should be fine.
Let me know what you find.
joe
Mar 22, 2009 at 8:35 AM
