1998 Plymouth Voyager service engine light & cold air &
JO79
  • 1998 PLYMOUTH VOYAGER
Heater problem
1998 Plymouth Voyager 4 cyl Front Wheel Drive Automatic
I own a 98 Plymouth Voyager and just today the heater started to blow cold air and my "service engine soon" light won't go out. My antifreeze overflow was completely dry and I refilled it. When I started it the light is still on. Is it because I was low in fluid or is it my water pump or heater core that's bad?
Monday, February 23rd, 2009 AT 8:17 PM
BMRFIXIT
  • 19,053 POSTS
Low coolant or engine running hot will cause a check engine light to come on
by adding coolant will not turn the light out it need to be reset
check for coolant leak
check and replace the thermostat
Monday, February 23rd, 2009 AT 8:39 PM
