1998 Plymouth Voyager Rear End Vibration
1998 PLYMOUTH VOYAGER
134,020 MILES • 6 CYL • 2WD • AUTOMATIC
GREENHEAD200
I have a Plymouth Grand Voyager that has developed a substantial rear end vibraton.
At very slow speeds, the vibration is exagerated to a wobble.
At higher speeds, the vibrations seems to diminish. The faster I go, the less noticable it becomes. at 75-80, it is almost unoticable.
I have examined the tires and tire pressures, but nothing has become of those searches.
Last, but not least, the vibration at highway speeds, seems almost rhythmic. The vibration starts out as normal, then over a span of a few seconds it fades away, then fades right back in again. This pattern continues over and over about every 2 seconds or so. I've never experienced anything like it.
Any ideas?
Dec 31, 2007 at 2:32 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e053f257f2="GreenHead200"]Suspension problem
1998 Plymouth Voyager 6 cyl Two Wheel Drive Automatic 134020 miles
Any ideas?[/quote:e053f257f2]
check tires again
run your hand over the tires looking for a flat spot
Dec 31, 2007 at 3:36 PM
GREENHEAD200
[quote:5c3bb4dc51="BMRFIXIT"][quote:5c3bb4dc51="GreenHead200"]Suspension problem
Any ideas?[/quote:5c3bb4dc51]
check tires again
run your hand over the tires looking for a flat spot[/quote:5c3bb4dc51]
I did that as part of my initial search. I so wanted it to be a tire problem, but I can't see anything.
Any other ideas?
Jan 2, 2008 at 12:41 AM
BMRFIXIT
  • 19,053 POSTS
[quote:019ad14aec="GreenHead200"][quote:019ad14aec="BMRFIXIT"][quote:019ad14aec="GreenHead200"]Suspension problem
Any ideas?[/quote:019ad14aec]
check tires again
run your hand over the tires looking for a flat spot[/quote:019ad14aec]
Any other ideas?[/quote:019ad14aec]
is it 4wd van you have
also did you check the balance
unless you haVE 4 wd van you dont have any moving parts in the back but the tiers and bearings
so jack van up and check bracks bearing
let me know
Jan 2, 2008 at 4:56 AM
