1998 Plymouth Voyager power steering leak
1998 PLYMOUTH VOYAGER
135,000 MILES • 6 CYL • FWD • AUTOMATIC
SJPD1959
I have a 1998 plymouth voyager with a power steering leak i was told the rack&pinion steering is leaking could this be true and how hard is this to do?
Apr 4, 2009 at 12:37 PM
CARADIODOC
  • 34,381 POSTS
The rack and pinion assembly has three seals. Leaking power steering fluid is very common. Although replacement is usually easier than on other car brands, this is not a do-it-yourself project.
If you don't believe your mechanic, take it somewhere else for a second opinion. These guys are trained to understand how improper tightening of bolts can lead to objectionable noise, threaded hose fittings can easily get cross-threaded and ruin the housing of the new assembly, and a whole list of other things that can go wrong to cause other problems.
A four-wheel-alignment must be performed after replacement of the assembly.
caradiodoc
Apr 5, 2009 at 5:32 AM
