1998 Plymouth Voyager oil pressure sending unit
1998 PLYMOUTH VOYAGER
15,800 MILES • 4 CYL • FWD • AUTOMATIC
EUCREDAWWG
hi,
i have a question that i foun dout is more puzzling than i 1st thought itwas, i have an oil light that come son when the van is idling, i want to change the oil pressure sending unit, i called auto zone and they asked me for teh vin numver which is, 2P4FP25B8WR644061- now this is what auto zone said was confusing, the van shows on the drivers side door sticker, that it was mfd in canada 12/97 but on my title it says its a 1998.. so they was wanting to knwo which oil sending unit do i need for my van also, where is this loctaed, i found a connector in behind my notor, on bottom of block, about 10 inches on left side of oil filter ( towards center of motor) it has a grren plastic clip on it, when i pulled teh clip off theres i think 3 square holes inside the connector. auto zone said they wasnt sure which sendin unit it takes bc it was made in canada and their books dont show it, for w/e reason, might u have a diagram, that shows, where the unit is?? so that i can be sure to take out the correct unit? id appreciate any hlep u can give me, asap. thanks sincerely Tim Johnson. eucredawwg@yahoo.com
Sep 24, 2009 at 12:54 AM
JDL
  • 16,098 POSTS
Welcome to the forum. My info shows the o/p switch to be on back side of engine block. One wire connector, the wire color is gray.
Sep 24, 2009 at 9:26 AM
