hello i have no brake lights the bulbs are still good but they do nothing when you press on the brakes i would appreciate any suggestions
Dec 20, 2009 at 4:12 AM
JDL
✓Experienced Mechanic
Welcome to the forum, check fuse 13-- 20 amp in power distribution center, under the hood. Not only check fuse, use a testlite on the fuse circuit, it should be hot all the time. Next, I'd check the circuits at the stop lamp switch. Possible issue with stop lamp switch?
