1998 Plymouth Voyager my van
JANET1958
Shakes or Wobbles problem
1998 Plymouth Voyager Front Wheel Drive Automatic 108000 miles
my van shakes at 40 then stops when i hit 50 in speed
Mar 3, 2010 at 12:35 AM
More than likely this is a tire issue or excessive runout on a wheel or hub.
So, we need to start with finding out where you are feeling the vibration. Is it in the seat or the steering wheel? If it is in the seat then more than likely it is the rear wheels, tires, hubs. If it is in the steering wheel, then that would be the front.
Here is a guide that will help with tire wear issues:
https://www.2carpros.com/articles/how-car-tires-work
Also, below is a chart that will help as well. Please inspect the tires and we can go from there.
Thanks
Nov 24, 2021 at 9:53 AM
