1998 Plymouth Voyager MAP SENSOR
JOHN SANCHEZ1
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • 153,000 MILES
WHERE IS THE MAP SENSOR LOCATED AND HOW HARD IS IT TO GET TO
Thursday, October 23rd, 2008 AT 1:07 PM
  • 109,885 POSTS
Hi:
Location is based on engine type.
3.0L - Is located in front of the air intake plenum between the alt and theromstat housing.
2.4L - I located on the end of the intake manifold, near the oil filler cap on the valve cover, just above the fuel rail.
3.3L - Is located on the end of the intake manifold near the throttle body
NOTE: The MAP sensor contains a 3 pin connector.
Let me know if this helps.
Positive feedback is appreciated.
Wednesday, November 5th, 2008 AT 1:47 PM
