1995 Plymouth Voyager won't stay running
1995 PLYMOUTH VOYAGER
140 MILES • 6 CYL • FWD • AUTOMATIC
NESTEGG
my daughter's van has had fuel pump replace...map sensor....she put dry gas in it it started ....she left it run for about 10 min....and when she stepped on gas to move it died...she tried to restart it wouldn't .....another day she tried again same thing....she had someone looking at it there saying it might be timing chain.....would that happen ...do you have any suggestions....she is a single mother of 4 and cannot afford to take it to a dealer
Nov 3, 2008 at 10:00 AM
  • 110,244 POSTS
Hi:
It could be timing, but usually when the chain or belt goes bad, it doesn't run at all. Did she have the fuel pump relay checked?
Nov 4, 2008 at 2:52 AM
PATRICE MAYO
1995, 3 Liter v-6 engine, just stops running. It's like it loses pressure and you can hear the engine strain if foot is on the gas. Release the gas pedal and you might go another mile, but then it hust dies and will not start. Flicking the key in the on position a few times might get it to start, but before you can put it in gear it dies again. Did a complete tune-up: oil change & filter, spark plugs and wires, fuel filter, replaced alternator belt. Want to know could it be the fuel pump or does the fuel pump have a relay of it's own. Then is it the catalytic converter? I've used the gas treatments twice to a quarter tank of gas, but no change. Any suggestions?
Apr 5, 2016 at 4:56 AM
