1998 Plymouth Voyager knocking sound louder during idle als
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
RHIANNAMARIE
1998 voyager with 3.0 knocking and vibration more noticeable during idle had fuel pump and filter replaced 7 days ago mpg has gone down aprox 5mpg check engine light back on 3 days after repair (check engine light on and ac rd def rwiper buttons blinkining since purchase 18 months ago) after repair the check engine light was off blinking stopped but now knocking. last january engine seals camshaft and crankshaft replaced breaks new as well as plugs cap rotor wires and hoses we just spent 600.00 please help i thought i had everything done possible to do[img:18ef396365]http://www.2carpros.com/forum/automotive_pictures/395419_08122009_083350AM_1.jpg[/img:18ef396365]
found by wheel in drive way
Aug 11, 2009 at 4:36 PM
2CARPRO JACK
  • 11,533 POSTS
What repair made the light go away? when you say vibration, is it like a misfire? If mileage has suffered, then it may be down 1 cylinder, this could explain the noise and vibration.Was it doing this when they did the engine seals? did it start after the work was done? how does the oil look, any metallic shine to it?
Aug 13, 2009 at 12:41 AM
RHIANNAMARIE
[quote:635f80a14f="2CarPro Jack"]What repair made the light go away? when you say vibration, is it like a misfire? If mileage has suffered, then it may be down 1 cylinder, this could explain the noise and vibration.Was it doing this when they did the engine seals? did it start after the work was done? how does the oil look, any metallic shine to it?[/quote:635f80a14f]
not like a misfire litelaly like something down in the front is loose or vibrationg the fuel pump made all the lights do away the check engine is back in i know there is a random miss in one of the cylnders but this almost seem like an exhaust rattle but it idles at 1/2of what it was before 10000 rmp if i step on the gas and brindg it up to that idle speed no noise driveng no noise only on stopped idle no gas given hot as loud even when in gear quiet on freway mileage is holding no it has never made this sound before and it is very diffrent than when the cam and seals were done it was fine no noise after seals and no change ex one door pl stopped working fuel pump and filter it when things changed lights all stopped and only check engine has come on is it possable something is not connected tight if i had to guess it is somewhere by the oil pan or just above sometimes it sounds like near a/c compressor? still driving but if it is something that i would be doing more damage by driving un fixed i want to repair please advise 3 car places have said it is dying no mech has auctually took codes or examined just listen to running they all wast 100.00 even jbs who did the pump and they knew 1 day after there was noise that was not there when the fixed the pimp for 600.00
oil is clean 1/2 way to needing change 1500mi on oil clean no shine or metal no chunks smells new not dark or black nice new color and smell not using any or burning any no blow by ect
Aug 31, 2009 at 6:36 PM
2CARPRO JACK
  • 11,533 POSTS
Take the vehicle and the bolt back to whoever did the timing belt/seals and ask them why parts are now falling off of your vehicle and why does it make this noise/vibration since you worked on it? Talk to the manager at minimum.That looks like it could be a mount bolt which could cause your problems.If they wont do anything about it, threaten with litigation.You by law have to give them a chance to make it right, after that the gloves come off
Sep 1, 2009 at 12:47 AM
