1998 Plymouth Voyager Intruments not working
1998 PLYMOUTH VOYAGER
186,450 MILES • 6 CYL • FWD • AUTOMATIC
JAZZUNIQUE1
I have a 1998 Plymouth Grand Voyager SE, the speedometer, fuel, temp gauges don't work for long periods of time and begin to work on their own at different times, but more than not. What is the cause of this problem and what can I do to fix this.
Mar 7, 2010 at 3:20 PM
LEGITIMATE007
  • 5,121 POSTS
I suspect a loose connection behind the gauges, it will need to be removed and checked, there are screws surrounding it, your just gonna remove those and then remove the ones that actually attach to the unit itself . pull it out and look behind, if this doesnt fix your problem then the body control module will be the fault.
Mar 7, 2010 at 11:36 PM
MCLEANROBERTS
I have a similar problem I just posted. Have you solved your problem? If so, how? thanks.
Mar 13, 2010 at 12:41 PM
