1998 Plymouth Voyager instruments panel
160,000 MILES • 6 CYL • FWD • AUTOMATIC
CENTELLA
I open the ignition switch, any light is on in the instruments panel but the engine start running well,
I can not see the gear position and the speedometer It doesn't work.
Apr 3, 2010 at 10:56 AM
JPEKAREK
I have had this happen on 3 different plymouth minivans. It's always the electrical connector behind the insturment cluster. The solder joints on the circuit board are poor and crack over time. This is 99% of the insturment failures on these vehicles. Don't let a shop sell you a new insturment panel. It can be easily repaired in about an hour by a competent mechanic.
Apr 4, 2010 at 4:48 AM
