1998 Plymouth Voyager Instrument Cluster Gauges don't work
1998 PLYMOUTH VOYAGER
125,000 MILES • 6 CYL • FWD • AUTOMATIC
AARONSTRAND
All fuse checked good, have trouble codes P1695 and P1698 basicly no bus communication between body mod. and pcm the odom. and trans indacator come on for about 10 sec when key is turned on and then goes out. Van drives and shifts good I don't know if I should replace the body control mod or Instument Cluster ? Every thing else works ok. note .my scan tool will only talk to the PCM
Sep 27, 2009 at 8:41 AM
BMRFIXIT
  • 19,053 POSTS
Remove cluster and check connector pins to the board
Sep 27, 2009 at 10:37 AM
