1998 Plymouth Voyager insterment cluster
1998 PLYMOUTH VOYAGER
145,000 MILES • 6 CYL • FWD • AUTOMATIC
ROGERWITH2
My 1998 Grand Voyager SE, the gauge cluster will all just droup out allong with the ABS light comming on, however I still have the anti-lock brakes. From my research that I have done this seams to be a common issue, but I have not heard of a fix for it. Do I need to change the whole cluster and the BCM, and where can I locate the BCM at? Can you help-me "PLEASE"?
May 18, 2010 at 4:24 PM
SERVICE WRITER
  • 9,123 POSTS
Very common there are a couple of solder spots that go bad on them. Some require a resitor replacement. If you are electronically oriented then take it out and take it apart. Otherwise plan on a remanufactured or used cluster.
May 19, 2010 at 12:49 AM
