1998 Plymouth Voyager inside panel door removal
JONATHANKLAIN
I took out all the screws I could find, but i still can't remove the door. How do I do it?
Nov 25, 2008 at 7:26 AM
DAVE H
  • 13,383 POSTS
DOOR TRIM PANEL
Removal & Installation
Using a trim stick, pry courtesy light from door trim. Disconnect courtesy light connector. Remove door assist handle (if equipped). Remove door pull cup (if equipped). Using a trim stick, remove screw cover from switch panel.
Remove screws securing switch panel to door trim and remove panel. Using a trim stick, remove seat/mirror memory switch (if equipped). Remove screw securing door trim to door panel from behind inside latch release handle.
Disengage clips holding door trim to door frame around perimeter of panel. Tilt top of trim panel away from door to gain access to latch linkage. Disengage clip holding linkage rod to inside latch release handle. Separate linkage rod from latch handle. Remove door trim panel. To install, reverse install removal procedure.
Nov 28, 2008 at 8:06 AM
