1998 Plymouth Voyager Fuel delivery problems
1998 PLYMOUTH VOYAGER
150,000 MILES • 6 CYL • FWD • AUTOMATIC
AL0NS0O
I have a problem with my Grand Voyager, first: the fuel pump stop working.. i've replaced it.. then i tried to start the engine, no succes.. then i realized that i had missed to refill the fuel pump assem.. after doing that finaly made it run.. and it was working good for about 20 minutes.. then i turn the engine off, 2 hours later i couldn't turn the engine on.. there's no pressure on the fuel rail.. do i need to have more fuel than a quarter tank? what can be the problem?..
May 28, 2010 at 1:55 PM
When you turn the key on-Do you hear the fuel pump come on? If so,check the fuel pressure.
May 28, 2010 at 2:09 PM
