1998 Plymouth Voyager fans
140,230 MILES • 6 CYL • FWD • AUTOMATIC
WOLFSBAR
I have a 98 plymouth voyager van........ today we went to eat and came out and the car wouldn't start.... come to find out the cooling fan was still running...... ended up pulling a fuse and got the fan off..... then had to get a jump start to get the vehicle running........ well long story short it would start to overheat when sitting still since the fans weren't running........ also the ac/heat unit has lights blinking that won't stop.....
Thanks,
Wolfsbar
Sep 22, 2008 at 3:13 PM
BMRFIXIT
  • 19,053 POSTS
Relay module at the frame behind front grill
need to have it replaced Direct power to fan motor from the battery if it comes on inspect and test the fan relay and the computer control of the relay-don' come On replace fan motor
good luck
Sep 24, 2008 at 5:39 AM
