1998 Plymouth Voyager failed insturment panel and lights
18,800 MILES • 6 CYL • FWD • AUTOMATIC
WOLF67
i have a 98 voyager and the headlights and insturment panel went out and have been out for awhile now i have tried the resoldering the insturment panel board and that worked for awhile and then it stopped working i replaced the battery and the battery cables all fuses were checked visually and with a volt metor any suggestions would be very helpful i use the van for work thank you for your time
May 16, 2010 at 8:42 AM
BMRFIXIT
  • 19,053 POSTS
Instrument board soldering is very common failure and I would take it apart and check again
May 19, 2010 at 10:52 PM
