1998 Plymouth Voyager Engine vibration when stopped in Driv
1998 PLYMOUTH VOYAGER
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
PKAZ
Grand Voyager 3.3L - Low, rough vibration when engine running but stopped in Drive - significantly reduced when put into Neutral or Park. Just had a tune-up (new sparks, wires, filters) and PVC. What should I be asking the next mechanic to look at? Thanks for an excellent resource, glad I found it!
Apr 3, 2009 at 8:10 AM
CARADIODOC
  • 34,381 POSTS
If you ask them to look at something, that's what they're going to do. You need to tell them what the problem is and let them look for the cause. From your description, I'd start by looking at a mispositioned front engine mount rubbing metal on metal.
Exhaust components can make noises too if pipes are rubbing on the body or mounting brackets. Less common is a mis-positioned power steering hose transferring pump noise into the passenger compartment.
caradiodoc
Apr 5, 2009 at 5:39 AM
