1998 Plymouth Voyager driver's side power window
1998 PLYMOUTH VOYAGER
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOEPAN12
The driver's side window suddenly stopped working, and seems to be partially off the track? It will go down (sometimes) under power but won't go up anymore.
I can push it up (to close it) but it slips down a little and soon, while driving, is about half open again.
The passenger window works fine, same as it always has.
Suggestions, please? Thanks, Joe
Jul 18, 2010 at 5:14 AM
CARADIODOC
  • 34,383 POSTS
Hi Joepan12. Welcome to the forum. This is a cable-driven system like is found in most vehicles now. If a plastic pulley cracks, the cable can become frayed and tangled. I never actually had to repair one, but I saw a lot of coworkers squatting down while chasing the coiled-up spring across the floor of the shop! I guess they can be pretty frustrating.
I've seen web sites listing rebuilt window regulators, otherwise this will be a dealer item. The entire assembly with pre-strung cables is replaced as a unit. If you have to use your old motor over, be careful if / when you pop the cover off. That's where the wound-up spring lives, and he's just waiting to escape.
caradiodoc
Jul 18, 2010 at 5:33 AM
